Hello, we are using terraform integration to set incident_urgency rules. We have the following setup
resource "pagerduty_service" "tech_team_x" {
name = "[${var.tech_label}] Team X"
auto_resolve_timeout = "null"
acknowledgement_timeout = "null"
escalation_policy = pagerduty_escalation_policy.team_x.id
alert_creation = "create_alerts_and_incidents"
incident_urgency_rule {
type = "use_support_hours"
urgency = "severity_based"
support_hours {
days_of_week = [1, 2, 3, 4, 5, 6, 7]
end_time = "23:30:00"
start_time = "08:30:00"
time_zone = "America/New_York"
type = "fixed_time_per_day"
The problem is we get this error:
Error: PUT API call to https://api.pagerduty.com/services/PUZ73WZ failed 400 Bad Request. Code: 2001, Errors: [Active urgency must be in high, low, or severity_based.], Message: Invalid Input Provided
which makes no sense since we are clearly setting urgency to severity_based.
We also tried the following variation:
during_support_hours {
type = "constant"
outside_support_hours {
type = "constant"
support_hours {
and this doesn’t work either. Now I get
│ Error: PUT API call to https://api.pagerduty.com/services/PUZ73WZ failed 400 Bad Request. Code: 2001, Errors: [During support hours is invalid.], Message: Invalid Input Provided
Can someone please help? I believe the first one should have worked as per [docs] (https://registry.terraform.io/providers/PagerDuty/pagerduty/latest/docs/resources/service) but I am not sure what we’re doing wrong.
To be clear, ideally, we want the incident Urgency to be severity_based regardless of support_hours setup.
